Project data & BIM
Archicad 26 missing MEP macros from IFC hotlinks when opening AC 25 file.
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:685148 | E417C3BC-CE55-453B-5305-EC644D023B1A)
Can't find Macro: MEP_m_RequestSystemGlobals, called
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 722.gsm. (Pipe Types:CF Pipe - Sch 80:685467 | E2ABDF1F-40BB-AB6D-B6A3-636F9428BF2C)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80 - with pipe tap:689632 | 1626FF00-B2C5-35AD-AAC0-25CCD2967C38)
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 715.gsm. (Pipe Types:CF Pipe - Sch 80:685148 | E417C3BC-CE55-453B-5305-EC644D023B1A)
Library part was not converted properly (M_Transition - Generic:Standard:689264 | 3078591A-8700-B200-E21A-DB2B00B644FC)
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 93.gsm. (Pipe Types:CF Pipe - Sch 80 - with pipe tap:689632 | 1626FF00-B2C5-35AD-AAC0-25CCD2967C38)
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 26.gsm. (M_Transition - Generic:Standard:689264 | 3078591A-8700-B200-E21A-DB2B00B644FC)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:399494 | 019D5609-7D85-70D4-9A23-5C3BB8DB7F2E)
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 154.gsm. (Pipe Types:CF Pipe - Sch 80:399494 | 019D5609-7D85-70D4-9A23-5C3BB8DB7F2E)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:248361 | A49E19FA-9D5A-2B87-9341-6163314FDB6A)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:778459 | 5E044D10-F75F-52CB-A03D-8ACD045A98C2)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:444837 | 456B8914-D350-7137-9186-DFFED1B4C86C)
Archicad 28 ARM, MacBook Pro M3 Max 128Gb, macOS Sonoma.
/Operations Director /BIM Lead /Architect @ www.airc.digital ltd ™
M Architecture & Urbanism ARB
4 REPLIES 4
Seems like you have not loaded the MEP Library that can be found in your Archicad Program folder.
Thanks for your answer, but as I mentioned this is a AC25 project opened in AC26 so the same libraries are loaded (including the MEP library).
It looks more like a library macro not being available in AC26 that was used to convert the IFC hotlinks.
That macro is definitely in the MEP Library 25.
So if you have that library loaded, it shouldn't be missing.
It is also in the MEP Library 26 as well - so you could load that library instead.
I have no idea why it would say the macro is missing if the library is loaded.
sayon3d
Save the project as PLA in AC 25.
Then open it in AC 26.
Let us know if this worked ok?
