Project data & BIM
Building Material Value Limits
Can anyone tell me the character limit for the "Description" parameter of Building Materials. I am setting up an automatic attribute generator so i need to know what limit to put on this field.
I have found the Building Material name has a character limit of 255 though I will probably keep the content I create under 32 characters. However, for the Description value i got to 500 and then got bored counting so thought I would ask the good people here so everyone can get the answer.
Thanks,
PS. sorry for not engaging with this site very much, I hadn't set up notifications until now. I will be here more often.
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
I have checked it and the character limit for the Building Material Description field is indeed 1024 characters, just as I thought.
Thanks Laszlo, that number makes sense.
