2023-03-27 04:26 PM
The panel of a curtain wall system has a CW Double Door type; (see attached screenshots). How to add this door type to the door schedule?
Solved! Go to Solution.
2023-03-27 05:15 PM
add a first line to your schedule criteria "Element type is panel OR"
2023-03-27 05:40 PM - edited 2023-03-27 05:52 PM
Thank you, Bruno.
2023-03-27 06:16 PM
It's because unlike doors placed in walls withe the door tool it's a 3D projection not a symbolic one.
If you want the door panel open set the 3D opening angle options to 90°.
If you want to see the opening lines you'll have to draw them manually.
Select the schedule cell then clic the annotate button and draw the lines
