Hundreds of unwanted Surfaces reappearing in Surface Palette
waydowntown
Hi everyone
Shortly after starting any project with our standard office template, a couple hundred new surfaces always appear in the Surfaces palette. If we delete them using the attribute manager, it's just a matter of (short) time before they reappear in the palette. Now I'm pretty sure these are embedded in a library object (or family of objects) located within our own office library (let me know if you think I'm wrong on that). Is there any way of pinpointing which objects in our library  are linked with these surfaces so that we can remove them?
Incidentally the surfaces are all named Kling RAL. Does anyone know where this might originate from?
Mac M1 Ultra OS 12.3
Since AC 4.55
20 REPLIES 20
Aaron Bourgoin
You've been bitten by the KLING virus. There is a macro inside the Kling Library that creates these. Stop using the part immediately and delete any KlING related objects from your libraries.
Worse still, the surface will keep returning when you copy paster anything from one file to another. (this nasty part can show up even if al you copy/pasted was a line). You will have to keep checking your Embedded libraries because it will keep coming back.  If you share arched files with other firms, they will be infected too.
Graphisoft this this is a feature. See related threads about copy/pasting bugs. We need to have the underlying functionality behind this disabled.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
Hmm, I wonder how this could have happened? šŸ˜‰
But seriously, we have nothing Kling -related in our library. So it should be a copy/paste function from a previously infected file. But I can't seem to reproduce this intentionally when copying several stories form one file to the next. Is there any other way that this might be passed on? And is there something specific that I should look for in the Embedded Libraries that will confirm this? Or any way to locate the Kling macro?
Thanks!
Since AC 4.55
look in the embedded library of your infected file first. then search your company library (libraries).
If it came from outside (do you receive archicad files from anyone?), then it will likely have infected your file(s) when you copy/pasted. They will be in a folder that bears the name of where they originally resided.
the macro uses the term Kling. I don't have an infected file open at the moment, but if you see it remove the enclosing folder.
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
Patrick M
Mentor
as others have said, check your embedded library. look for any object called master_gdl.gsm
these are "storage dumps" for attributes or sub-routines. They are generally usefull, for the out of the box library. But some manufacturers attach them to their parts to conveniently give you all their furnitrue/appliance/fixture finish options. The biggest issue is that this pollutant is contageous. If you copy/paste from a file with these master_gdl.gsm parts into a clean file, even just copying over some lines, fills, or texts, the embedded library part comes with it, and it generates all the surfaces in all the files.
eventually, you will find every project in your office will be contaminated, and you'll have to clean them all out regularly. I have a client that I scrub all their files about 2-3x per year, and have even gone through their archives to weed it out. But theres always that one project form 10 years ago that we need a detail from, and the design staff doesnt think to look for the pollution before copying it into their file. By the time it's caught, it's in 75%+ of the current projects again.
THIS is one of the biggest PITA's of my Archicad work
it's not just that file or file type.
The ones that relate specifically to the Kling bug are these:
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
yes, thats exactly what I was referring to. The master_gdl parts are dragging surface attributes everywhere. and they pollute every file you copy/paste into
dsfahsdfhn
How is there no fix for this yet? I'm at the point where I too, have to clean out every file in my office periodically...
We have 40 active projects in the office, most of which involve more than one single model file. Despite our in-house  NO COPY/PASTE rule, the re-infection happens every week to 2/3 of the files.
It is a virus: not a feature.
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
scottjm
Mentor
@JaredBanks video about the Master_GDL virus is very informative and well worth a watch to better understand this virus.
https://shoegnome.com/2023/08/03/archicad-tutorial-92-copy-and-paste-embedded-libraries-and-master_g...
