Project data & BIM
Layer combination intersection group numbers??
Is there a quicker way to change Layer combination intersection group numbers other then one by one?? Thanks
You need the "Intersections in Layer Combinations" Goodie.
Download and Install the Goodie from Graphisoft's website: http://www.graphisoft.com/downloads/goodies/index.html
After you've done this, re-apply the Hotfix for your current build to complete the installation. It should appear as a new item in the Options Menu after you re-launch.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Cool thanks! I will give it a go.
