Project data & BIM
Local file to teamwork?
Hello, can we help me a little? one of the employees save work as local file, but he work in teamwork from bim server(something with pc, ethernet off), can we now some how load this file to server?
Noemi Balogh
Hi Inadzuki,
If you can access the BIM Server, it is possible to Share any .pln/.pla on it. Just open the desired project then go to Teamwork > Project > Share...
If you were not logged in before, enter the BIM Server's address, the username and the password.
Also, make sure you have at least a Project Administrator permission (so you are able to share).
Kind regards,
Noemi
Noémi Balogh
Community Expert, Admin
Rember that when the file was modified offline and also team was made some changed online you need to take care of managing changes manually. In such a case, we take the most update file and add changes from the other file.
