Project data & BIM
Project Indexes fields - Project Info
Titiriga
Hello!
I'm trying to make a layout list that includes the name and code of the layouts in a subset.
Each of my layouts has a code composed of the Layout ID, the Subset ID and a few other entries from Project Info (like Project code, Project Status etc.). This code appears on the layouts in a text box that uses Autotext references. I know how to make a layout list using Project Indexes - Layout Index, but the problem is that the fields available to list are only from the Layout and Transmittal Set categories, not from Project Info.
Is there any way to make such a list?
Thank you
0 REPLIES 0
