4thorns wrote:
Do you think I am totally off base here?
Not totally... but close, if I am reading between the lines correctly.
Yes, you should have saved views for those things, but the basement, main floor, loft/second floor, and roof should each be on its own story - 4 stories total. You might model the site mesh and put it on a story below the Basement to get it out of the way, giving you 5 stories. Etc. There are some here who put floor framing on a separate in-between story, but I feel that complicates the automation that you get for labeling/numbering stories in section, etc.
If those things are NOT on separate stories, you've probably more than doubled the amount of work and error-checking involved, and missed out on being able to have wall heights follow story heights and other features.
By using stories (and renovation filters if you do remodels), you can get by with a very short list of generic layers. Consider your Wall-Interior layer. It can hold any wall that is existing, demo, or new on any story. Just one layer. Your visibility is controlled by viewing the desired story, with the desired simple layer on, and the desired renovation filter. Oversimplifying the depth of what can be done, but that's the idea.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
