Project data & BIM
Why are these unique ID objects appearing twice in a schedule?
We have an issue with correct surface area in one of our schedules. There are 2 walls with stone in this project but they are each appearing in the schedule twice. Does anyone know why that would happen? I've attached a pic of the scheme settings and of the schedule which clearly shows the unique ID of both objects appearing twice. Thanks in advance,
AC27 USA - build 5001
HP ZBook 15 G6
Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM
Windows 10 Pro
6 REPLIES 6
Andre_Steynberg
I had a similar issue only with roofs over here : https://community.graphisoft.com/t5/Document-Visualize-forum/Excel-Import-Element-is-duplicated-in-S...
For interest sake what kind of wall is it? Composite, complex profile etc?
Andre Steynberg
Win 10 64-bit
AC27
Miha Nahtigal
Your schedule should be of "Elements" type, not of "Surfaces"
It's a composite wall, but with only one building material in it.
HP ZBook 15 G6
Windows 10 Pro
I created a new elements schedule and it appears to be working correctly now. That still doesn't explain why the same unique ID object appears twice in one schedule.
HP ZBook 15 G6
Windows 10 Pro
Also, I made a copy of the AC file and now the original surface schedule does not have duplicate items in it. Seems to be a bug in the original AC file???
HP ZBook 15 G6
Windows 10 Pro
I guess because the Wall has two sides and both sides are considered as individual surfaces in the Surface Schedule.
