Project data & BIM
Window Schedule Scale
mattmgut
I am using a schedule to show window types in elevation view.  When I set the scale to 1/4" (in this case), the views are changed to 1/4".  However, when I put the view on a layout it changes to a different scale.  I have "Redefined with Current Settings" in the tab, but it reverts back to a different scale.  Bottom line is, the scale function in the schedule preview seems glitchy.  Is there something I am missing?  Have others had success with this feature?
Thanks,
Matthew
AC 27, MacBook Pro M2 Max
2023 MBP, macOS Ventura 13.3.1
Archicad 26
1 REPLY 1
mattmgut
I think I figured it out.  I overlooked that the view settings for the schedule in the layout needs to be at the same scale as the schedule preview.
Archicad 26
