Project data & BIM
phantom wall intersections....
for some reason i have walls cutting where there is a wall on another layer but turned off. is there any way to change this (other than removing the hidden wall)?
using AC 9 build 2172
thanks
Under Layer Settings, select the layer combination that has the wall layer you referred to turned off, then change the intersection group number (next to 'layer name' on the layer list) for the layer you want off to a different number.
Update the layer combination (bottom button on the left column in the center) and you should be all set.
When the intersection group numbers are the same they will clean up with each other, when they are different, they won't and you can change the numbers by layer combination.
hope that helps
-edit: just caught that you have AC9 so this may not work for you - anyone else know?
Laura Yanoviak
Yes -- the procedure is the same for AC9.
AC26 US (5002) on Mac OS Ventura 13.5
