Read more
Project data & BIM
Read articles about BIM-based management of attributes, schedules, templates, favorites, hotlinks, projects in general, quality assurance, etc.
Articles
Previously deleted Interior Elevations reappear in the Navigator after Sharing/Reloading the Teamwork Project
Affected versions: 20 | Severity: no workaround applicable | ID: 216288 Note: We plan to fix this issue in the next regular update of ARCHICAD 20. Issue: If you place an Interior Elevation group on the Floor Plan, delete some of the Viewpoints from t...
wp-content_uploads_archicadwiki_moniker-images_icon-info.png wp-content_uploads_2016_10_IE-bug-AC20-1024x594.png
How to list the Wall Surface
In ARCHICAD listing/scheduling the Wall Surface is not possible if the Zone's body was modified with a Solid Element Operation. Until the correction is implemented there is a possible workaround. Basic idea Instead of the Zone we will list a Morph, c...
wp-content_uploads_2016_10_02-1-1024x682.png wp-content_uploads_2016_10_03-1.png wp-content_uploads_2016_10_06b-1024x345.png wp-content_uploads_2016_10_08.png
Archicad 19 Performance Troubleshooting Guide
Even though Archicad 19 is faster than ever, performance related issues can come from various causes. Most of these issues can be due to the insufficient Software/Hardware availability or the way how the project is created in Archicad. Depending on t...
Calculation/Schedule - Troubleshooting Guide
Known issues Incorrect results in the surface schedules if the composite of a wall is changed Affected version: 19,20 | Severity: workaround applicable | ID: 190411 Issue If the composite of a wall is changed in the Interactive Surface Schedule to an...
wp-content_uploads_2015_06_Surface-schedule-before-composite-change-1024x244.png wp-content_uploads_2015_06_Surface-schedule-after-composite-change-1024x244.png wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_archicadwiki_fireratinglistingparameter--011.jpg
Ed Brown Graphisoft Alumni
  • 3806 Views
  • 0 comments
  • 0 likes
Favorites - Troubleshooting Guide
In ARCHICAD 20, Favorites get a fresh look and feel, right in line with the new user interface. In addition, Favorites are now much easier to use, which makes their power accessible to beginner and expert users alike. The fundamental behavior of Favo...
wp-content_uploads_2016_07_StructureOutsideontheRight.png wp-content_uploads_2016_07_PreviewContourObjects.png Info_18x18.png
mtron Graphisoft
  • 2041 Views
  • 0 comments
  • 0 likes
Tab Based Navigation - Troubleshooting Guide
This Troubleshooting guide will show you the new special functions of the Tab Based Navigation. If you want to learn how this Navigation works detailed please go to the ARCHICAD Reference Guide Tab Bar section. As of ARCHICAD 20, when you switch betw...
wp-content_uploads_2016_06_NamesOntheTAB.png wp-content_uploads_2016_06_VPNamesOntheTAB.png wp-content_uploads_2016_06_ExclInNamesOntheTAB.png wp-content_uploads_2016_06_ContextMenuofTABs.png
mtron Graphisoft
  • 1594 Views
  • 0 comments
  • 0 likes
Save and Apply Favorite Settings
Most architectural firms have a standard set of element settings they use repeatedly, in multiple projects. These may include standard Walls, Doors/Windows, Composite Slabs. This article describes how to save these standard element settings for later...
wp-content_uploads_archicadwiki_saveandapplyfavoritesettings--favorites-01.png wp-content_uploads_archicadwiki_saveandapplyfavoritesettings--favorites-02.png wp-content_uploads_2011_06_01b.png wp-content_uploads_2011_06_02.png
  • 2611 Views
  • 0 comments
  • 1 likes
SQL Queries
"(...) Someone asked me privately if there was a way to extract all of the layer settings for every layer combination in order to document all of the Layer combinations in an external program such as Excel or Access." This tip is an example of using ...
wp-content_uploads_2016_06_01.png wp-content_uploads_2016_06_02-1024x692.png wp-content_uploads_2016_06_03.png wp-content_uploads_2012_01_show-data-structure.png
ARCHICAD 18 performance troubleshooting guide
Performance related issues can come from various causes. Most of these issues can be due to the insufficient Software/Hardware availability or the way how the project is created in ARCHICAD. Depending on the nature of the issue you experience check t...
Info_18x18.png wp-content_uploads_troubleshooting_nvidia-265x300.png wp-content_uploads_images_Screen-Shot-2014-06-18-at-16.47.28-e1403102899375.png wp-content_uploads_fig9.gif
XLSX export from ARCHICAD can result in corrupt files
Issue If the Energy Evaluation Report is exported using the default .xlsx file format it becomes corrupted under certain circumstances. Files of the same format can also be corrupted when saved from an Interactive Schedule. The circumstances of this ...
wp-content_uploads_2016_02_export-1024x711.png wp-content_uploads_2016_02_save-as-xlsx.png wp-content_uploads_2016_02_error-message-1024x133.png wp-content_uploads_2016_02_repair.png
User Interface - Troubleshooting Guide
ARCHICAD 19 Solo is flashing on every zoom/pan Issue: ARCHICAD 19 Solo USA language version may blink noticeably whenever the program redraws the 2D views (Floor Plan, Section/Elevation) on Macs with Retina Display. Solution Drag the slider of the 2D...
wp-content_uploads_2015_12_2D-hardware-acceleration.png wp-content_uploads_2015_07_External-content-missing.png wp-content_uploads_2015_07_Navigator-Drawing-Manager.png wp-content_uploads_2015_07_place-external-drawing-WE.png
Work Environment - Troubleshooting Guide
The External Content Menu is missing from the File menu in ARCHICAD 19 Solo edition Issue The External Content menu is missing from the File menu therefore the Place External Drawing command and the Drawing Manager menu is also missing from the defau...
wp-content_uploads_2015_07_External-content-missing.png wp-content_uploads_2015_07_Navigator-Drawing-Manager.png wp-content_uploads_2015_07_place-external-drawing-WE.png wp-content_uploads_archicadwiki_bugs-missingtooltips--tooltip.png
Background Updating
Background Updating Background Updating uses idle processor capacity to generate the 3D model and its associated BIM data for open windows and tabs. Before AC19: When switching to another open window, all model generation for that window would begin ...
Attribute Troubleshooting Guide
Known issues Exporting an STB file with special characters in its name results in empty file Affected version: 16-19 | Severity: workaround applicable | ID: 192007 NOTE: This issue was fixed in ARCHICAD 20 release version. Issue If you export a pense...
The most common alerts in Archicad
This article will try to summarize the most common error messages, and alerts to be able to help you to understand them better. Teamwork Send and Receive Error Messages Please find the collection of Teamwork alerts here: Teamwork/SendReceiveErrors Pe...
wp-content_uploads_archicadwiki_errormessages--1.jpg wp-content_uploads_archicadwiki_errormessages--2.jpg wp-content_uploads_archicadwiki_errormessages--3.jpg wp-content_uploads_archicadwiki_errormessages--4.jpg
ARCHICAD 17 performance troubleshooting guide
Slowdown on MacBook Pro Retina with Trace containing a Drawing Issue Pan, zoom, navigation and creation of new elements can be extremely slow on machines with high resolution screens when the Trace & Reference is turned on and contains a drawing. Upd...
wp-content_uploads_archicadwiki_troubleshooting-slowmacbookproretinawithtrace--lowresolution.png Info_18x18.png
Attribute Manager
The Attribute Manager (Options menu) is a handy tool to create and manage the Company-standards in your Archicad projects. Its commands allow you to copy (append, overwrite) attributes (Layers, Layer Combinations, Pens & Colors, Line Types, Fill Type...
Screen Shot 2022-12-01 at 11.38.33.png Screen Shot 2022-12-01 at 11.36.49.png
mtron Graphisoft
  • 2288 Views
  • 0 comments
  • 0 likes
Top 12 ARCHICAD Commands You Should Use all the Time
Would you like to work faster and more efficiently in ARCHICAD? We have collected 12 lesser known shortcuts in ARCHICAD International version that can ease your daily workflow: Highlight Toggle Shortcut: TAB Have you ever wanted to select a Zone inst...
wp-content_uploads_archicadwiki_topcommands--quickselection.png wp-content_uploads_archicadwiki_topcommands--quickselection01.png wp-content_uploads_archicadwiki_topcommands--forceguidelines.png wp-content_uploads_archicadwiki_topcommands--hideguidelines.png
Replace Attributes by File: Automate Attribute Migration
If you are migrating multiple similar project files to Archicad 17 , the Replace Attributes by File function can help you speed up the migration process: it automates the Delete and Replace attributes function, instead of you having to issue repetiti...
Info_18x18.png wp-content_uploads_archicadwiki_attributemigration--1.png wp-content_uploads_archicadwiki_attributemigration--att2.png wp-content_uploads_archicadwiki_attributemigration--att3.png
  • 2946 Views
  • 0 comments
  • 1 likes
Template Files
See also: Template Files in ARCHICAD Help A template is a read-only project file with extension tpl. Why should I create my own template Templates are intended to cut down or eliminate the time to create a new project by reducing the repetitive task ...
wp-content_uploads_archicadwiki_templatefiles--save.png wp-content_uploads_archicadwiki_templatefiles--open.png
automata Graphisoft
  • 4054 Views
  • 0 comments
  • 0 likes
Multistory Hotlink Modules
See also: Hotlinked Modules. Multistory Hotlink Modules can be used, for example, to compare the different designs of a building easily. In our example we are working with Elizabeth Tower project, designed by Andrea Horvath and Kiss Iosif-Andrei (win...
wp-content_uploads_archicadwiki_multistoryhotlink--type1.png wp-content_uploads_archicadwiki_multistoryhotlink--type2.png wp-content_uploads_archicadwiki_multistoryhotlink--multistoryhotlinkedmodules-03.png Info_18x18.png
  • 2825 Views
  • 0 comments
  • 0 likes
Layer Extras
Updating Views and Layer Combinations via the Context Menu – by Link Ellis, Worldwide Consultant "If I am working along in a view and decided that I want to turn a couple layers off so I click and hide them through right click, or through the palette...
wp-content_uploads_archicadwiki_updatingviewsandlayercombinations--hidelayerfromcontextmenuuj.png wp-content_uploads_archicadwiki_updatingviewsandlayercombinations--sortedalllayersandselectedlayercombotochangeuj.png
automata Graphisoft
  • 1411 Views
  • 0 comments
  • 0 likes
Cost Calculation Using Interactive Schedules
In order to estimate the costs in a project please take the following steps. This example will calculate the individual and total costs of the four doors (two of which are identical) in the plan below. Step 1: Set Cost Values for Elements in the Proj...
wp-content_uploads_archicadwiki_costcalculation--01.png wp-content_uploads_archicadwiki_costcalculation--02.png wp-content_uploads_archicadwiki_costcalculation--03.png wp-content_uploads_archicadwiki_costcalculation--04.png
automata Graphisoft
  • 3062 Views
  • 0 comments
  • 0 likes
Building a Pen Chart with SQL
"(...) I'm imagining a utility object that will automatically build a pen chart in the floor plan window with a user defined array of squares and accompanying text label for each pen. It would be a great help when introducing new coworkers to our pen...
wp-content_uploads_archicadwiki_penchartwithsql--01.png wp-content_uploads_archicadwiki_penchartwithsql--02.png wp-content_uploads_archicadwiki_penchartwithsql--03.png wp-content_uploads_archicadwiki_penchartwithsql--04.png
automata Graphisoft
  • 1260 Views
  • 0 comments
  • 0 likes
Typical 3D and 2D Speed Problems - Troubleshooting Guide
3D Summary of Typical problems Too many polygons count number of polygons with PolyCounter tool (Help menu > ARCHICAD [version] Downloads) to determine polygon count find objects with too many polygons watch out for objects coming from 3DS, C4D forma...
wp-content_uploads_archicadwiki_2dspeed--feedback.png wp-content_uploads_archicadwiki_2dspeed--navioptions.png wp-content_uploads_archicadwiki_2dspeed--updateoff.png wp-content_uploads_archicadwiki_2dspeed--snappoint.png
Quick Layers Palette
Originally published at Cadalyst, written by Eric Bobrow Principal, Bobrow Consulting Group Editor's note: This tutorial is courtesy of Archicad. Archicad's Quick Layers palette complements the Layer Settings dialog box that allows layers to be turne...
Screen Shot 2022-12-01 at 14.48.31.png Screen Shot 2022-12-01 at 14.49.12.png Screenshot 2022-12-02 at 11.04.37.png wp-content_uploads_archicadwiki_quick-layers-palette--4.jpg
automata Graphisoft
  • 6095 Views
  • 0 comments
  • 1 likes
ARCHICAD Office Standards and Templates
This article is written by Eric Bobrow, Principal of Bobrow Consulting Group.Office standards set the graphic appearance and organization of documents produced by a firm. They also play a significant role in promoting consistency, efficiency and usab...
wp-content_uploads_archicadwiki_archicad-office-standards-and-templates--1.jpg wp-content_uploads_archicadwiki_archicad-office-standards-and-templates--2.jpg wp-content_uploads_archicadwiki_archicad-office-standards-and-templates--3.jpg wp-content_uploads_archicadwiki_archicad-office-standards-and-templates--4.jpg
automata Graphisoft
  • 9642 Views
  • 0 comments
  • 3 likes
ARCHICAD's Powerful Clone Folders
Originally published at AECBytes: http://aecbytes.com/tipsandtricks/2007/issue24-archicad.html written by Eric Bobrow Principal, Bobrow Consulting Group Within the Navigator View Map, ARCHICAD has a powerful, yet little-known and underutilized featur...
wp-content_uploads_archicadwiki_archicad-s-powerful-clone-folders--1.jpg wp-content_uploads_archicadwiki_archicad-s-powerful-clone-folders--2.jpg wp-content_uploads_archicadwiki_archicad-s-powerful-clone-folders--3.jpg wp-content_uploads_archicadwiki_archicad-s-powerful-clone-folders--4.jpg
automata Graphisoft
  • 2503 Views
  • 0 comments
  • 0 likes
Tips to set up Work Environment
At the bottom of the Start Archicad dialog box, you can select your preferred Work Environment profile. Unlike Project settings, Work Environment settings are saved not as part of the project, but in a local folder on your computer. The individual se...
Screen Shot 2022-11-11 at 13.53.34.png Screen Shot 2022-11-11 at 13.55.18.png Screen Shot 2022-11-11 at 14.00.26.png Screen Shot 2022-11-11 at 14.14.45.png
automata Graphisoft
  • 2926 Views
  • 0 comments
  • 0 likes
