Installation & update
ArchiCAD + Office Set-up Sytems
I have a small architectural practice, one without an IT oficer, and no experience with setting up a CAD office. Consequently, I would like any help that I can get beyond the STS system of how to organize, set-up etc.. the basic office standards for a small practice trying to use the very large program of ArchiCAD...
thanks....Paul
11 REPLIES 11
As for when to model, we always draw in 3D it helps when your looking at certain construction elements, where you can cut a section line or see it in 3D view so you can determine how your going to do something, its much better to understand in 3D/Section than trying to work it out from a 2D view.
As for layers, being a small practice we usually use some of archicads standard layers i.e. external walls, Internal walls (though depending on stories we usually have a set for each storey) drainage, external works on separate layers, furniture, lighting, plumbing etc etc.
We try have a standard but some jobs are just non standard, and it depends on how your office works and the type of projects as to what a good layer combination would be.
Also to make it easier to go through the layers we always purge unwanted layers that Archicad set, especially if we have merged a site plan map from Ordnance survey as they add about 300 layers to your drawing of which probably only 50 are used for that particular site plan.
Thats how our office works at the moment, but we are trying to form a set of commonly used layers for all the projects we have done on Archicad over the last 16 years to create a template for any job, though you can agree this is quite difficult to do as no job is ever the same.
I think you are on the right track and personally feel that an office template that is specifically set up for your needs will save you 1000's of dollars in saved time down the road. If you hire a consultant to help you with this you might consider waiting for 10 since the templates will change with the new features of 10. I am of the philosophy of using as few layers as possible, using non cryptic layer names, and using a layer organizing strategy that makes locating a layer simple. For me this represents about 65 layers on a new construction project and close to 100 for a remodel. As mentioned previously, the "project framework" book is a good resource and I would recommend this to any new user. This forum is a great resource and reading everything in it for your first year will be invaluable. Good Luck.
