Installation & update
Codemeter Key with 2022 MacBookPro 16 (USB-C only)
Gene Kniaz
Hi all:
So this probably has a very obvious answer since it doesn't look like anyone has posted about it, but how do I get Archicad to "Authorize" without a USB-A port - will a simple cable adapter (i.e. usb-c to usb-a) work? I looked in the Archicad License Manager app to see if there was a way to "convert" the CM key to a software key, but I didn't see any indication that's do-able. I'd like to keep the CM key anyway since it makes it easier to move between my iMac and the new laptop.
Thanks,
GK
Yes, the adapter will work. Single, or USB hub.
Thanks Ignacio!
GK
