Installation & update
MENUBAR/TOOLBAR GRAPHIC ERROR
kaphase
See graphic error on buttons in menubar and toolbar. There are horizontal or vertical lines running through buttons depending on their size and orientation. Happened after I updated project from 23 to 24, but may be unrelated. See images:
[AC24-27 USA - Mac Studio 2022 - Apple M1 Max - 64 GB - macOS Ventura 13.6]
Monterey is not supported yet on AC24, you will find information about it on this page when it becomes available:
https://community.graphisoft.com/t5/Setup-License-articles/MacOS-12-Monterey/ta-p/309154
The page currently says:
Archicad 25 is compatible from the already available 2nd Update(40xx build).
Archicad 24 will be compatible from its 5th Update (70xx build), which is planned
to be released in February of 2022. Until that please be aware of the known
compatibility issues detailed below.
Hello ka,
You should specify your operating system as well as your hardware configuration.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
