Teamwork & BIMcloud
BIMcloud Libraries showing empty
Kinga Wolter
we have a network of 10 workstations (Windows 10), and BIMcloud Basic 22 is running on a different computer. Only one computer out of these will show empty BIMcloud libraries in ALL Teamwork projects we open. All the rest of the computers load the library objects perfectly in the same files. See pictures below:
Could someone please explain how this could happen?
Thank you for any help!
Kinga
Kinga Wolter
Project Director / BIM Manager
Intel(R) Core(TM) i7-4770K CPU @ 3.5 GHz, 32 GB RAM
NVidia Quadro M4000 1GB, 250 GB HDD, WIN10 PRO
User since AC13
Aaron Bourgoin
Delete your the Libraries from your Local Data Manager. This will force a reload of the libraries from the BIM Server.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
4 REPLIES 4
Aaron Bourgoin
MacBook M4Pro
Rhino 8.25 Mac
MacOS Tahoe 26.1
Kinga Wolter
Perfect, thank you Aaron!
It worked. What can bug down the Local Data folder?
Kinga Wolter
User since AC13
David Larrew
This a 22 bug we reported last year. Still waiting for a Hotfix that actually fixes this. Probably never going to happen since 23 has been released and they are busy attending to the 23 bugs.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Noemi Balogh
I might be a bit late for the party, but you can find an explanation about this issue on Help Center:
https://helpcenter.graphisoft.com/knowledgebase/119387/
NoƩmi Balogh
Senior Community Expert, Admin
