DNS failure?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2012-07-03 11:28 AM
The error goes on for 4-5 minutes and then the user is again able to work properly on TW, even though the DNS error is still on...
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-06 03:22 AM
is your bim server machine using a fixed IP?
Your ping results seem to suggest yes but the obvious questions etc.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-06 09:17 AM
And all the macs on the office LAN have the serve's IP adress first on the DNS settings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-06 01:17 PM
Other than that it sounds like you might be entering 'bug' territory, sorry.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-06 01:30 PM
I was afraid Im facing a bug...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-07 03:24 PM
The troubleshoot server connection dialog may not be robust enough to help
the user.
The third section in the following wiki article may be of help:
http://archicadwiki.com/Teamwork/ConnectionProblems
It is possible that the DNS service is not answering fast enough and the
timeout before retry may be the source of the delays.
Also, the issue was been entered into the bug database.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-13 10:21 AM
What is the current state of the problem? Could you achieve any improvements?
Regards,
Technical Support Engineer
GRAPHISOFT
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-16 08:34 AM
the problem persists as I described it. Could not make any progress.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-17 10:28 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-07-20 09:56 AM
1. The client can not reach the server through port 6005 (default discovery port in the BIM Server preferences) May the port is not opened on one of the computers. You can easily check this with telnet.
2. May you have changed the discovery port in the server but did not set each clients accordingly. The same port has to be set in the Client ArchiCADs in the Work Environment on Network and Update tab.
3. Other network or network configurational error.
The communication via the discovery port uses UDP as well (besides TCP/IP) what has to be allowed on each router, server between the client and the BIM Server computer.
If the server runs on a normal OS not on a server type it can limit the number of the current TCP/IP connections to 128. Increasing this limit to 512 or 1024 could help. In case of OS X we recommend this article:
Generally teamwork functions are independent from the discovery function so they still work when the discovery service of the server is not available.
GRAPHISOFT
