Teamwork & BIMcloud
Default snaphot settings
Josh Verran
Whenever a new project is shared on teamwork, I need to manually go into the project settings and change the snapshot settings from 10 hours to 1 hour.
Is there a way to adjust the default setting, so all new projects have the above interval set?
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
LinkedIn | www.creativespace.co.nz | Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
1 REPLY 1
Noemi Balogh
On BIMcloud and BIMcloud as a Service it is an available option to schedule snapshots from the root folder, so this is easy to achieve. In case of BIMcloud Basic, the only way unfortunately is to schedule project by project.
Kind regards,
Noémi
Noémi Balogh
Community Expert, Admin
