Drawing Tool and Teamwork
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-04-16 05:18 PM
‎2019-04-16
05:18 PM
I uploaded the images as a library to the bimcloud.
When opening a project on a computer that does not have the local file they obviously come up as "missing"
How can I link the image reference to an image in a bimcloud library?
Tomasz Mlynarski
New York based Architect
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-04-17 08:31 AM
‎2019-04-17
08:31 AM
Hi Narska,
It is not possible to place external drawings from your BIMcloud library, unless they are objects.
Recommended workflow here would be:
1. Place external drawings with File / External Content / Place External Drawing... command.
2. When you placed the drawing, select it and on the info box (under update type) / in the settings dialog (Identification part, on the bottom after update types), check the option called "Store in the Project".
This command will save your drawings to the project, so other users will be able to see it as well. On the other hand, it is likely that your project size will significantly grow because of stored drawings.
Kind regards,
Kind regards,
Noémi Balogh
Community Expert, Admin
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-04-17
08:31 AM
Hi Narska,
Kind regards,
Kind regards,
Noémi Balogh
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-04-18 02:13 AM
‎2019-04-18
02:13 AM
Thanks for the info
Tomasz Mlynarski
