Teamwork & BIMcloud
I keep having to restart Bimserver18
Haneef Tayob
Every few days we find that we cannot access the Bimserver18.
A reboot resolves it.
Any idea on what could be the problem?
We've almost never had to reboot Bimserver17/16/15
PC has a static IP
It's mostly (but not always) when we start work in the mornings
Its running off a standalone Windows 7 64 bit pc
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
7 REPLIES 7
Eduardo Rolon
Here are the "restart" commands so you don't need to restart the computer, though restarting might be easier.
http://helpcenter.graphisoft.com/?p=41958
and the post discussing it,
http://archicad-talk.graphisoft.com/viewtopic.php?t=46626
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Marton Kiss
Please collect the BIM Server logs and we will check what might be going wrong.
Sent you an upload link and instructions in PM.
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
We are also having this problem. Any solutions to this ?
Marton Kiss
Steve,
we identified the source of this and will release a solution with the first update of version 18 coming early Fall.
Marton
Marton Kiss
GRAPHISOFT
Hi Marton
Thanks for the update. Will save us chasing it at our end.
Steve
roderick_sarco
Hello, glad to see the issue has been identified. We are also experiencing issues with the Bimserver being not available in the morning. Extremely troublesome, since if people from other time zones are trying to log into a project, then they cannot do it until the people at the server's time zone arrive to restart it.
Any ideas of when the first AC18 update is coming out? We are having lots of other problems and are hoping the first hotfix may help.
Roderick Anderson
Design Director
SARCO Architects Costa Rica
www.sarcoarchitects.com
Glauco L_cio
Marton wrote:
Steve,
Marton
Hi Marton,
I'm having the same issues. The Update 4020, released in October 30, has the correction to the problem? Can I use the Update in a Brazilian Version of AC18?
Glauco Lúcio
Arquiteto e Urbanista
