Teamwork & BIMcloud
Just moved from v11 to v16 - sharing questions
Hello all,
Under v11, we'd been very used to using layers to distribute our work, instead of marquee, etc. It appears that this is much less straightforward in 16 now. This seemed to work very well for us, and its been tough to settle on the best means of dividing up a project - any advice?
Thanks,
GK
You can reserve by layer, layer combo, story, and much more. I thought that there were lots of examples in the Help?
A good resource for the 'new' TW is the Wiki. Start here:
http://www.archicadwiki.com/Teamwork
and
http://www.archicadwiki.com/Teamwork/WorkFlowFAQ
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
I would say one of the biggest difference between the old and new Teamwork is that in the new Teamwork you don't really have to divide your owrkspace in advance. Reservation and Release of elements can be done in a few seconds on the fly. It is immensely more flexible.
