Are you sure it is a teamwork issue, Gary? A similar behavior can result if you had saved a selection-as-module with the checkbox to replace the original elements with a reference to the module, and if grouping is suspended.
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
