Visualization
AC23 -> Twinmotion & CI roof accessories issues
Hi there
Imported AC23 model into twinmotion, I assume this is a common issue with using the Cadimage roof accessories tool, there are similar display issues when exporting to a bimx also but specifically this is happening for me in twinmotion with the polygons all being reduced anyone have a solution?
Also the colours are totally different and the brickwork material I have applied in archicad has been replaced by a default brick material twinmotion, which I dont want to use and cant be made to look like my original brick pattern, i just want to keep my materials and colours on importing.
After a bit of searching i found the way to change the settings within archicad to work in Twinmotion
Guru
For anyone else who stumbles across this thread, the roof geometry issue is caused by the "Optiomize the geometry" option. Refer to this thread.
Ling.
