Archicad 25 Elevation missing texture fill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-04-23
11:56 PM
2022-09-28
08:12 PM
Oleksandra Vakariuk
Hello everyone,
I am very new to the Archicad program. and I am really happy to join in to learn more.
I liked the idea of the appearance of the elevations with the material I select for walls and other objects. but unfortunately it worked once and then it disappeared. I tried redoing the same elevation default settings again but it shows just colors with no presenting for the real material.
can anyone please help.
- Labels:
Project Presentation
Surfaces
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-24 03:22 AM
Try turning off Fade Distance Elements, or adjust the settings of Fade Distance Elements so Uncut fill is also set to "Surface - Texture Fill".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-24 08:33 AM
Also, make sure you don’t have any Graphic Overrides active.
macOS Sequoia (15.1.1)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-24 12:05 PM
Thank you for your support. I just figured out the problem!
I was changing the settings for elevations but it did not make any changes to any of the elevations. so we I entered the settings of the East elevation that is when the view changed. so apparently I need to change every elevatons' setting separately and this is what solved the problem.
Thank you for answering, and since I am new this is not going to be my last question 🙂
see you soon.
