Visualization
CineRender MAXON in ArchiCad21
Hi!
I'm learning how to render in CineRender MAXON in ArchiCad21.
I used Artlantis before.
I got w problem in queuing views to render. In Artlantis I had Batch, and I can click "Render Later" and run all renders at night or at weekend. I can't find this option in CineRender, does it have it?
It's more difficult to run one render at time and wait 2h to run another.
Thanks for your help.
And also, sorry for my bad english 😉
alemanda
you can use the publish function ...
just create the views to be rendered and then publish them to a directory at once.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
alemanda
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
This is exactly what I was looking for.
I'm still learning, thanks a lot for your help
