Render in CineRender turns Black
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-02-24
06:34 AM
2023-05-11
11:40 AM
Noemi Balogh
2016-02-24
06:34 AM
The problem I am having, and it seems to exist no matter what I do, is that when I have my camera facing upwards (i.e. higher than the height of the camera itself, even by a tiny bit) the render turns completely black. If I have the render facing at head height or lower then it renders absolutely fine. This is a big issue for the perspective renders as the building is tall.
If anyone has any solutions as to why the renders turn completely black when the camera is looking slightly up it would be really helpful.
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-02-24 11:02 AM
2016-02-24
11:02 AM
Maybe the camera is inside a wall or other element ever so slightly if it turns up, try moving the camera a little forward.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-04-20 10:53 AM
2016-04-20
10:53 AM
HI All, we did not hear back from the user, so hopefully the problem got sorted out. Best, kata
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
GRAPHISOFT
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-04-21 03:07 PM
2016-04-21
03:07 PM
I have the same problem , please i need help ASAP , after i choose my setting and start the render it prepares for about 9 second then turns black ... Thanks in advance !
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-04-21 03:26 PM
2016-04-21
03:26 PM
Check that you have enough RAM for rendering.
Check that the camera is not inside a wall or object or the like. If you save the camera in to a path, you can show it on floor plan. Saving camera is a good idea also to be able to reproduce the excact same render later, if you make changes to the design.
Check that light is turned on (at 100%) in the Cinerender settings.
Try some of the preset scenes. Start with the 'quick render' ones, working up to medium. Final render settings are very heavy and often not needed.
Read up on known issues here:http://helpcenter.graphisoft.com/troubleshooting/3d-modeling/texture-overwrite-fails/
Most common setting to tweak for nice results:http://helpcenter.graphisoft.com/troubleshooting/3d-modeling/texture-overwrite-fails/#CineRender_and...
www.leloup.nl
Windows 10 Pro
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-01-27 08:03 PM
2021-01-27
08:03 PM
I had the same exact problem, but this video helped me with the issue. Apparently you have to add window lights and change the diffuse depth, primary/secondary intensities for an interior rendering to show up correctly.
