Visualization
TV custom picture in screen
rob2218
How to do this?
it's been talked about. I looked up the threads....yet...neither the tutorial nor the threads will show me how to change the object TV image to a custom JPG?
I've tried to select a JPG to "add" to the embedded library.
Have tried to follow all the notes on here but to no avail.
Also...the files were are trying to show that TV custom photo is a TW file with hotlinks.....if that helps any with the library responses.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
15 REPLIES 15
I can't get it to NOT work. I used the same parameters as you show... including a 7' diagonal (!!) screen... and my image shows fine. I'd say it is something with your image file, except that it is working for you with the old style tv object.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Are you sure that you have the checkbox set to use the object's surfaces? If unchecked, the entire TV including the screen will be all one material.
rob2218
SOoooo...you left the stand "ON"?
and that showed the image? What the #$%$%???
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
I'll recheck it sir...
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
YOU IZ DA MAN!
that was it!
the "use objects materials" was NOT checked on.
you DA MAN sir!!!!
i>u
Edgewater, FL!
SOFTWARE VERSION:
Whew. Glad that worked. 🙂
