2015-05-15 02:07 AM - last edited on 2023-05-11 01:56 PM by Noemi Balogh
2015-05-15 04:04 AM
Brad wrote:You're not the only one
Please see the enclosed images. When you look at a window through the door glass the window disappears. I am out of ideas.
2015-06-04 09:00 AM - last edited on 2021-10-23 12:45 AM by Laszlo Nagy
I believe you need to change ray treshold and depth settings to fix your issue.
Go to PhotoRendering Settings, check Detailed Settings under CineRender and then navigate to Options - General Options.
Hope that helps
2015-06-04 05:13 PM
Brad wrote:So when you move the camera out side the window re-appears, correct?
2015-06-08 01:53 PM
2015-06-08 05:47 PM
2015-07-22 11:12 AM
