The Project Origin (World Origin?) is not adjustable.
You should be modelling close to the Project Origin at all times.
You can have problems in Archicad if you model a long way from the Project Origin.
The User Origin can be repositioned and is simply a reference point for you to work from - it will not affect the Project Origin.
If your model is far from the Project Origin then try moving the entire model closer and see if that helps.
