2019-06-20 08:01 PM
2021-01-07 06:03 PM
2021-01-10 07:26 PM
2021-06-14 05:55 PM
2021-06-15 03:33 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2021-06-15 10:27 AM
2021-06-16 06:46 AM
Braza wrote:
I think GO is not the place to include this capability, as I see it more as a presentation tool than a BIM one.
Ling is in the right direction... I would suggest an upgrade on the Surface Settings that could include a "Composite Surface" option. Where we could add several "Layers" of surfaces with individual custom properties (i.e.: Existent, Removed, New) that could be filtered by the user.
Better control for overriding individual surfaces given certain conditions, or adding an option to replace a specified surface
2021-06-16 07:18 AM
Lingwisyer wrote:
The end of my previous post was more about how theSurface Catalogueintegrates with the GO system. When you cannot globally replace an individual Surfacewithout deleting it, I see little hope in GOs being able to do it...
2021-06-16 11:13 AM
Lingwisyer wrote:I have the same opinion for GO. It is purely
Keep Surfaces purely visual as they are, construction does not belong there.
2021-09-17 06:15 PM - edited 2021-09-23 04:09 PM
The GO option works pretty much exactly the same as the renovation tool currently does, and the problem with both is that you cannot change a single side of the wall, you have to override the surfaces for the entire wall, in and out. Impractical for showing a client a before and after side by side comparison easily, as the renovation tool IS INTENDED to do.
And the surface painter is an option, but obviously you are also not going back and forth between existing and new easily. That is the obvious strength o the renovation filter, it just needs to be able to change only a SINGLE side of the wall as opposed to overriding the entire structure (or having to model 2 walls and this create the new/ existing/ demo layers that the renovation files keeps you from having to do).
