2023-02-05 10:32 PM - edited 2023-02-08 11:26 PM
When different complex profiled walls come together at different heights, most of the time walls don’t join the way you want. Material priority doensn’t do its job correctly.
I’d like to have the possibility to create a custom Wall End. Even beter: I’d like to have the possibility to choose a column as a Wall End. This way you can choose a (custom) complex profiled column as a Wall End. So at different Wall heights the Wall End can have different Ends. This way you can join all complex profiled walls correctly with each other, even at different heights. Would that not be great?
