Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Different fill on plan & section for walls
Haneef Tayob
Hello
I'd like to see an option in the wall tool, where one can specify a different plan and section fill. (I'm still using AC 8.1, so not sure if AC9 is different)
Example, I sometimes don't want to have the wall plan indicate a fill for low walls, but on section I want it to indicate brickwork.
thanks
Haneef
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
6 REPLIES 6
Stephen Dolbee
A long standing wish. I sometimes use the beam tool for low walls.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
If you search the wish list, you will see it about 20 times...
cremsberg
Here, Here! This is a must for the next version!
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
Haneef Tayob
This was a wish I made in 2005.
In many ways, it has been addressed as you now (from AC10?) have 'the floor plan display' options.
Haneef Tayob
cremsberg
Haneef:
When you say "floor plan display options", I think you are referring to what is now called Model View Options, right? I see that I can override a fill to make it either transparent, window or solid sill (depending on item), but I do not see where I can chose any other alternate fill, different from floor plan display, such as a cross-hatch or concrete fill. Am I missing something?
I am also following similar threads here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=133356#133356
http://archicad-talk.graphisoft.com/viewtopic.php?p=133064
Claire Remsberg
cremsberg wrote:
Haneef:
No, he's referring to Floor Plan Cut Plane
