Hey Podolsky,
I didn't say it was impossible... Just beyond of my knowledge. My GDL kungfu is not that strong.
Your GDL skills are very impressive. Specially by doing this in this short time. Even if I had the stamina, I would probably need months to achieve part of this. Basically I just use brute force (trial/error) for my GDL math.
I checked your label and it seems its working almost perfectly. I can see that the connections between lines are not mitering. I understand that the label can
not know what is the width of adjoining walls, but I think that if you assume that they are the same of the labeled wall it would miter properly. And then we could use the editable hotspots for fine tune (which I presume you put it there for this purpose
). I also put it to some stress regarding changing wall direction and reference line offset... It respond flawlessly. Very impressive. The arched line option is missing, but you included an editable hotspot to manually edit it. Very handy while waiting for an automatic solution. Anyway... Thanks for your contribution. I am sure a lot of users will benefit from your label object.
p.s.: But I still think that the GO Fill Orientation Option would be the ideal solution, as it could automatically add the symbolic fill thru specific criteria.
