2016-08-11 02:58 PM
2016-08-11 06:54 PM
2016-08-11 10:21 PM
2016-08-11 10:41 PM
Piotr wrote:Not to the point.
Use the forgotten selections pallete as a workaround for what You need.
2016-08-12 07:07 PM
2016-08-12 07:27 PM
laszlonagy wrote:None. There is no plausible solution for multiple elements selection, however a single element would not be a problem and might be a useful feature.
When you select elements in 3D, they may be elements with different Home Stories. So if you now go to the Floor Plan, only some of the elements selected will be visible on your Floor Plan. How is ARCHICAD supposed to show this? Go to the Story that is the Home Story of the last selected element (as indicated by the Info Box)?
What would be a good solution to this?
2016-08-12 07:57 PM
2016-08-12 08:55 PM
laszlonagy wrote:I don't see a clean-cut solution for multiple elements on multiple Home Stories.
In case of multiple elements some kind of working logic would have to be made.
2016-08-12 10:06 PM
laszlonagy wrote:Hi, I would say that it can be use the same logic of when you select multiple elements, which one do you see in the info box? the last, so probably having a simple logic that it will go to the first or last selected element floor will be logic, I think that is obvious for a user that if they select elements from different story you wont be able to see them all in one story.
Yes, for a single element it would be straightforward.
2016-09-13 08:22 PM
