‎2020-03-05 05:53 PM
‎2020-03-05 06:36 PM
‎2020-03-05 09:31 PM
DGSketcher wrote:
You should vote for your own poll, it might help sway GSHQ.
‎2020-03-05 10:47 PM
‎2020-03-06 02:34 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
‎2020-03-06 03:05 AM
‎2020-03-06 03:08 AM
Lingwisyer wrote:
You can manually set the window size then save that as a view. It is not the easiest thing to manage though as while setting it it is 1 to 1 so you cannot see beyond the extents of your monitor. As far as I can tell, it scales from your current window size linearly so you can first set an aspect ratio that fits within your monitors resolution to get the framing, then scale up to your desired resolution from there. Beware though that the 3D window may take quite a while to regenerate.
Ling.
‎2020-03-06 03:15 AM
rm wrote:
I wonder if the function works fine on a PC only
‎2020-03-06 05:04 AM
rm wrote:Hi Robert,
and a pallet comes up to change the overall pixel size for width and height - highlighted in RED. Once you hit, OK the image increases in size. In my case the whole screen goes black, not sure why. I then right click on the black screen and select, save and place in layout book.
‎2020-03-06 04:17 PM
