Wishes
Keyboard shortcuts for the pet palette
Juan Manuel
Will it be possible to put keyboard shortcuts to the slab or frame editing tools, etc.?
JaredBanks
Mentor
F and opt+F are next and previous pet palette items. Similarly G is next geometry method in the info box. Both are SUPER helpful keyboard shortcuts.
Jared Banks, AIA
Shoegnome Architects
Not for adding nodes or stretching edges, at least to my knowledge, but you can map drag, mirror, multiply, adjust, split, elevate, rotate,
JaredBanks
Mentor
Jared Banks, AIA
