I wish that we could adjust the angle of the wall ends just as we can adjust the angle of slab edges and beam ends. The wall-end tool has a flaw. It only works relative to the reference line of the wall in a limited range of angles. If we have many converging walls at one point for which I need the reference line to stay in place but the angle to adjust to the slab the wall is sitting on is relative to the wall thickness line and not the reference line of the wall, then you cannot give it the angle you need
