Many times, when I use Fillet for example Shell tool Archicad cannot produce a nicely smooth surfaces and polygons can be visible producing a coarse surface mesh. That is why I would recommend a general resolution settings panel that could handle the different display resolution method and performance. Like in case of Morph tool
Shell tool - There is a resolution panel at Revolved profiles however not for others. Alternative way via only Reg. keys. can help.
Curtain Wall - no resolution settings. To increase curtain wall boundary profile resolution at curved element we have to increase the Scheme consistency but in this case unexpected frames will be added to the object.
Complex Profiles - (sometimes it is not subdivided enough)
