2004-03-21 06:16 PM
2004-03-21 06:19 PM
2004-03-21 08:04 PM
Link wrote:Next thing is to connect those variables by means of mathematical functions. Interesting, I would suggest those improvements as a part of an existing Attribute Manager.
I would like to see a truly parametric modeling environment, and I think some kind of Variable Manager would greatly help this cause.
It's just a conceptual idea for now, but I think it could be a very powerful tool, without being too confusing!
Link.
2004-03-22 09:45 AM
2004-03-22 03:13 PM
stefan wrote:This is the way Allplan is meant to be used : very powerful : changing one parameter such as storey height changed the project correctly. The same behavior was possible for doors and windows defined in absoluter height or relatively to wall top/bottom values...
e.g. The height of this wall is "3m" in "absolute value", while the height of another wall is "-0.3m" "relative to" "next floor".
2004-03-22 05:39 PM
Geoffroy wrote:This should be additional/advanced feature rather than standard feature for beginners. ArchiCAD simplicity would be lost like it is case with Allplan.
2004-03-23 11:18 PM
2004-03-24 12:52 AM
oreopoulos wrote:I think the marquee tool is better for this purpose. It can be fine tuned to move/stretch exactly what is wanted. And the 3D marquee can be limited vertically (in plan of course it is just the current story or all of them).
I think this could be a part of a bigger thing.
When we build a column or an external wall most of the times the wall goes up to many storeys.
In current situation when moving a wall we should go and move all of its parts on all storeys. If we could bind them together so moving the wall would move all others at the same time OR ask if we want to break the binding condition.
I think this feature is in revit but i am not sure.
This kind of internal binding is very usefull.
2004-03-24 12:01 PM
Link wrote:I wish one could add global variable in your environnement and modify them in this environnement : this way, we could fine tune the object behavior based on specific global var.
This would be perfect for measurements, but could also be applied to attributes, such as materials, composites, fills, linetypes, etc.
2004-03-24 02:12 PM
