Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Zoom for Railing Pattern Editor
R Muller
I am working on a rail with 1/4" thick steel components as well as larger wood components. The problem is I can't see the smaller components very well in the pattern editor. Trying to select a 1/4" rail that is right up against a wood rail is very difficult, especially with my imperfect eyesight. It also doesn't help that the 1/4" rail looks wider in the pattern editor than the 1-1/2" wood rail that is right below it.
I keep instinctively scrolling the mouse wheel to zoom in on the pattern editor to better see the detail, but of course it's not possible. I would love to have a zoom feature, or else the ability to have the pattern editor in a separate window like a profile editor window.
R Muller
AC 26 USA (20+ years on ArchiCAD)
MBP 64GB Apple M1 Max OS 12.1 Monterey
9 REPLIES 9
Lingwisyer
Guru
+1
Should add a poll
R Muller
Good idea. Not sure how to add a poll.
R Muller
Lingwisyer
Guru
If you are still able to modify your initial post, it should be next to the attachment option at the bottom, otherwise one of the Mods will have the add it.
You go into EDIT your original post and then you should be able to create a poll.
If you still can't do it then I can do it for you.
Lingwisyer
Guru
Barry's fancy Mod options. What does "Warn user" and "Information" do?
I guess the last two option are particular for moderators only.
Warn user allows us to tag your profile with a warning message and we have the option of sending you a warning e-mail.
Information just gives us a little more info about the post and poster that you wouldn't see as a regular user.
Basically just a quick link into the moderator control side of the forum.
DGSketcher
Legend
+1 It would really help on the curtain wall scheme editor as well.
R Muller
Thanks, I have added a poll.
R Muller
Ghaleb Khadra
Graphisoft Alumni
Graphisoft Alumni
Hi All,
Thank you for requesting this feature, and for your active participation on the forums.
I am happy to say that we have added this into our Wish database.
As reference, the Wish number is 12575
Thank you all for sharing your ideas with us, and thank you all who voted.
[Stay Active. Stay Awesome ]
Kind regards,
Ghaleb
Ghaleb Khadra
BIM Expert
GRAPHISOFT
https://helpcenter.graphisoft.com
