Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
inconsistent level dimensions rounding
soldaotop
Hi
Could someone please point me out why Archicad has this weird inconsistent rounding thing with the level dimensions, and how to avoid it?
Why some level dimension are rounded to a higher value while the others at the same time are on the contrary rounded down?
So as it is visible the height of 8,5cm is rounded to 8cm, while the height of 38,5 is rounded to 39cm
Thank you
soldaotop
OK, my mistake my level dimensions was mistakenly put a bit lower than the slab itself 🙂
1 REPLY 1
soldaotop
