‎2003-11-08 04:02 PM
‎2003-11-11 06:06 PM
‎2003-11-12 02:06 AM
"Ben Odonnell" wrote:
You have my vote as well 😄 😄
‎2006-05-09 03:40 AM
Z.Bauer wrote:
I hope, that Graphisoft finally will add 3D Rotation function Tool, and that will work with any object.
‎2007-01-09 02:05 PM
Z.Bauer wrote:U have stolen my wish )))
‎2007-01-09 05:53 PM
‎2007-01-10 02:21 AM
Laura wrote:Thanks Laura,
FYI, there is this add-on:
OBJECTIVE
and it is reasonably priced...
‎2007-02-16 10:20 PM
‎2007-02-19 03:19 PM
TurboGlider wrote:Hmmmm...tough one...
I vote too, I can see some problems with that technically though, than we have trouble with 2d views if we can rotate anything like we want to and a slab in reality is a slab, not a roof or wall. But maybe you should have a 3d rotation on all objects (wall, slab, object...) but if you rotate any object, it has some function that convert it to an Complext Object.
Say : You build an complex windowwall with slabtool and beams. You mark all this objects and choose : convert to complex object and then it convert it to an GDL object but with the different that you could rotate it in xyz-plane? And the 2d representation you could choose between views like complex hide lines or outer contour.
And, why not than have a possibility to save this GDL code directly in your .pln file?
And why not go further? Why not have the ability to set ID like Mat1:Frame, Mat2:Glass and when you have converted your object, then in parameterlist for that complext object you have your rotating choise, and also parameters for Frame material and Glass material ?
What do you think about that?
Ben O, Mats K at lasercad in sweden, do your work! !!!
‎2007-02-19 03:34 PM
Mats_Knutsson wrote:Dooh, that's why I want those rotated object to be a new kind of Complex Object. A rotated wall or slab isn't a wall or slab after rotation, it's a complex object.TurboGlider wrote:
I agree on XYZ rotation on dumb objects but on construction elements I would be very nervous...
