2004-04-18 01:41 PM
2004-04-18 02:18 PM
2004-04-18 02:30 PM
kllk wrote:I tend to agree. But I don't think all we need is a bunch of new buttons and tools. I feel that the existing tools could easily accommodate many of this and maybe a set of transformers - this could be an extension of the Solid Operations feature, so instead of just having one object influencing another, but a set of transforms can act on an object (like twist, taper, bend, bulge, shear etc).
i am very surprised that AC has got to v8.1 and still no sign of tool that would allow for fast, easy and precise modeling of complex 3d objects (dont tell me GDL scripting is way to do it!).
id like to have working planes, 3D lines, tapering, twisting, piping, cutting etc tools in AC, even a simple palette like gdltoolbox would be a good start!
if graphisoft doesnt start to move in this direction i think AC is most likely to lose its edge over autocad and allplan.
2004-04-18 03:29 PM
2004-04-18 07:27 PM
James wrote:They also work in 3D window ...
Also, have the existing features like split, + and - to be able to work in any window including section/elevation and not just in plan.
2004-04-18 07:35 PM
kllk wrote:Allow me to disagree; 3D snapping is present, in plain ArchiCAD as well as ArchiForma. Working planes can be helpful, I agree. As I did my last AutoCAD model 10 years or so ago, I weaned myself off the workplanes, and am obviously less influenced by the surface modeling methods.
its not JUST TOOLS that i need but also the possibility to work in FAST and PRECISE manner in 3D. i think this is inconceivable without proper 3D snapping and working planes (archiforma has neither).
2004-04-18 08:59 PM
Allow me to disagree; 3D snapping is present, in plain ArchiCAD as well as ArchiForma.in archicad yes, but in archiforma no (for example you cant snap along line or have perpendicular/parallel constraints). id like to have ACs 2D drawing capabilities in 3D! if you ever had to make even the simplest spaceframe you know what i mean.
GDL is not scary, or hardwell, its not hard but is clumsy. making something with GDL script takes hours while in autocad is a matter of minutes! not to mention that equations are not a natural environment far an architect.
BTW, it is also my moderator's duty to remind you of the etiquette which does not allow anonymous usage of the Forum. We like to know each other, so please at least update your profile with the real informationsorry, i tryed to update my profile but i didnt know how to change my username...................................
2004-04-19 08:07 PM
kllk wrote:I do, trust meAllow me to disagree; 3D snapping is present, in plain ArchiCAD as well as ArchiForma.in archicad yes, but in archiforma no (for example you cant snap along line or have perpendicular/parallel constraints). id like to have ACs 2D drawing capabilities in 3D! if you ever had to make even the simplest spaceframe you know what i mean.
kllk wrote:Agreed; what happens when the span changes? Ha! Speaking of spaceframe - take a look at some of the examples in the CookBook. No, not easy to script, and much easier to just draw, oops, model.GDL is not scary, or hardwell, its not hard but is clumsy. making something with GDL script takes hours while in autocad is a matter of minutes! not to mention that equations are not a natural environment far an architect.
kllk wrote:User name is OK, if we know who you areBTW, it is also my moderator's duty to remind you of the etiquette which does not allow anonymous usage of the Forum. We like to know each other, so please at least update your profile with the real informationsorry, i tryed to update my profile but i didnt know how to change my username...................................
nevermind, my name is nenad jankovic, nice to meet you all!!!
2004-04-20 11:03 PM
kllk wrote:Take a look at FrameWright for 3D tools including 3D rotation, 3D cutting, working planes, and profiling (+no GDL scripting required). Refer to:
2004-04-21 03:50 PM
