2005-06-10 05:24 PM
2005-06-15 02:54 AM
2005-06-25 02:54 PM
andyro wrote:PM9 don't check how many drawings are on Layout when you use <DRAWINGSCALE>. Autotext is just manually linked to only one drawing that you set as autotext reference on the
...At least the <DRAWINGSCALE> Autotext should read the one (if only one) drawing scale on its respective sheet and fill itself out correctly no?
2005-06-25 04:19 PM
2005-06-25 07:15 PM
andyro wrote:To insert autotext for drawings just click on drawing for that you need autotext, right-click with mouse on it, then from context menu choose set as reference. Choose Text Tool and create a text box from >Edit_menu>>Insert AutoText for " "> choose AutoText that you need for your drawing(for exp. Output Scale). You can also find AutoText List in the context menu after right-clicking in TextBox string.
I haven't got drawing scale - and set drawing as autotext reference on a respective sheet to work yet, will have to try again. Is this in the particular drawing settings box?
Will check it out., thanks - A
