Wishes
Add ability to reassign category as different category.
For example be able to classify the Morph or Shell Object as beam or column.
Be able to reassign the wall as ceiling (if this will ever happen). When it serves as bulkhead only.
4 REPLIES 4
You can already change the classification of an object. Open the object settings, open the 'Tags and Categories' tab and within the 'IFC Properties' you can change the element type
Regards,
Scott
It applies only to IFC classification. If you take off quantities Morph is still a Morph not a column.
alemanda
Voted essential, especially for quantity takeoff purpose. Concept is good ... Implementing I think is difficult ...
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
You can still schedule a morph as a column you just need to add the IFC type column to the schedule
Learn and get certified!
