Vitruvius wrote:
Get rid of the segment lines on roofs in 3D and plan.
vitruvius
what you're wishing for is a small part of a huge big picture issue that we have been hassling garphisoft to fix since forever: this issue is not limited to roofs . . . archicad needs to be able to handle
real curved elements and not approximate them by faceting them into straight elements!
if i understand it correctly, this is going to require a huge re-write to the underlying modelling engine,
but unless it is done sooner rather than later all new features are still going to have this limitation
. it is
not good enough to simply farm things out to maxonform, nor is it good enough to give us new modelling capabilities in 10 (sloped/complex structures) that are
still restricted by this legacy code!
sort it out!
~/archiben
b e n f r o s t
