Or you can just make the wall 0 (zero) height.
You will need to make them 'Symbolic' floor plan display as well as otherwise you will lose the fill (below the cutting plane).
They won't show in 3D but they will still be selectable so you may need to be careful with that (i.e. put them in a layer that does not show in your 3D views).
Keeping them as walls may make it easier to edit them if you need to.
