Any reason why you wouldn't want to use a complex profile wall?
I know you can't stretch the individual heights of each skin but then you just add one wall on top of another (stack them in height) where the construction varies (and hope your openings do not span across the join or you are back to square one placing two openings).
Or you create a few different profiles with different height claddings that you can choose from.
You can also nominate the portion of the wall that will stretch in height in the complex profile if you need your stonework to always be the same height (i.e. 1000mm high around the base of all walls regardless of their overall height).
