I would like to be able to reverse the direction of a symbol line by a click of a button in the relevant dialog box/toolbox. At the moment there is no quick work around to changing the direction of a symbol polyline. So if you want to trace a fill or some other element using the magic wand its pot luck whether its the right way round or not.
I know it is a small wish but it would be a smart feature useful for revision bubbles and other asymmetric lines, and easy to achieve by just reversing the order of coordinates of the line/polyline.
I have also just found that the program will change the direction of a polyline by itself if you edit one end of it, which can be quite annoying when you have finally got the line the right way round. Hence it must automatically swap the coordinates around to edit it.
P.S. Firefox 2 is pretty smart for writing posts (instant spell checks -but doesn't recognise Firefox )
