Wishes
Combine dimension settings
Why do we have separate buttons / tools for lineal, radial and angular dimensions? If I set my text, arrowheads, line colours etc for one, surely I would most likely want the same settings for the others. Should this not be done with a single tool, then within the tool select the dimension type?
At least have a "uniform settings for dimensions" button, as with line / polyline / arc / spline settings.
1 REPLY 1
TomWaltz
I'd be REALLY happy to see a "uniform settings for dimension tools" option!
Tom Waltz
Learn and get certified!
